-   -   Fuel Filter on CARTER CARB (https://www.offshoreonly.com/forums/do-yourself-boating-budget/382624-fuel-filter-carter-carb.html)
powerqrudy 05-31-2024 06:55 PM
Ok i have a 29 Powerquest with 454s and they have Carter Carbs. Has anyone have ever changed the filters that are in the Carb ?
It soes not look like a hard job curious ?
thanks.
Steve The Oil Guy
compedgemarine 05-31-2024 07:10 PM
most carter carbs do not have a filter per se. they either have a screen behind the inlet fitting or they have a small screen on each needle seat.
powerqrudy 06-01-2024 11:35 AM
OK, that is a start.
Thank you for you insight.
Steve
Bondo 06-02-2024 09:17 AM
Ayuh,.... The important "trick" is to use 2 wrenches,.....
​​​​​​​One to hold the carb's fitting, 'n one to turn the line's nut, preferably a line wrench,....
splashandbun 07-20-2024 03:31 PM
very important
