-   -   540 Camshaft needed (https://www.offshoreonly.com/forums/do-yourself-boating-budget/382877-540-camshaft-needed.html)
Zinger 06-21-2024 07:06 PM
540 Camshaft needed
Hello All,
I'm looking to purchase a hydraulic roller cam for a Gen V1 540 engine but can seem to locate one. The engine is natural aspirated 9.5 with 305 AFR heads. Can anyone suggest or have a source for one.
Jeff
sutphen 30 06-21-2024 09:09 PM
how much power do you want to make?
Sporl Performance 06-21-2024 09:17 PM
I have cams in stock.
Ron 504-161-6005
sutphen 30 06-21-2024 09:30 PM
Ron 504-161-6005
what do you have?
SecondWind 06-21-2024 09:53 PM
Originally Posted by Zinger (Post 4901205)
Hello All,
Jeff
I've got these in a NA 588 build: Bullet 244/250 112 .664/.663 They make power and sound great.
Rookie 06-21-2024 10:37 PM
Hello All,
Jeff
I highly suggest a 3/4 race cam for your application.
A full race cam might be a little much.
boostbros 06-22-2024 06:43 AM
we run a very strong 540 bullet cams made the cam it is awesome and they are old school and fun to work with
sutphen 30 06-22-2024 08:33 AM
what gen blocks are your 540's,i have brand new bullet cams for gen 6,240,248 ls112 .620's lift double swap.
GLENAMY 242SS 06-22-2024 01:18 PM
Also can contact Hardin Marine, they have a couple of real nice HP camshafts, be careful not to go wild and create reversion.
Here is what my buddy runs in his built 540 and I run in my 509. Comp Cams 01-775-8 grind # CBVI XR271HR-12
.591/.601 224/232 @ .050 112 LSA (off the shelf cam).
sutphen 30 06-22-2024 06:10 PM
almost the crane 731,nice
GLENAMY 242SS 06-22-2024 06:24 PM
Exactly with a Comp cam off the shelf available number. 741's tent to revert
Ron Stroll has a similar cam he has Lanati grind for him in stock. Well worth a call to Ron, he also has anything from new blocks and rotating assemblies to all head/cam needs IN STOCK. Great knowledgeable guy to deal with.
Sporl Performance 06-22-2024 07:48 PM
I also have 525 cams.
Ron Sporl Performance
504-616-6005
Bad vert 06-23-2024 12:09 PM
what kind of power are you making
Tartilla 06-23-2024 09:13 PM
If the race course is only a 3/4 length, then a 3/4 race cam would be a full race cam?
Rookie 06-23-2024 09:26 PM
Hello All,
Jeff
What are your goals? You have suggestions from 580HP to 680HP cams?
Can't locate one? Pick up the phone and call Comp...
Griff 06-24-2024 01:54 PM
Hello All,
Jeff
Call Teague Custom Marine
