-   -   Exhaust tips (https://www.offshoreonly.com/forums/do-yourself-boating-budget/382913-exhaust-tips.html)
Dentdude1 06-25-2024 09:05 PM
Exhaust tips
What’s up guys. So I’m gonna swap out exhaust tips on my boat, currently has what appears to be muffled tips and I want it a little louder. I boat on a large lake with no houses nearby and majority of boats on the water are powerboats and cats so it’s not unusual. Just wanna make sure what I’m changing to isn’t gonna cause any problems with reliability or let any extra water back up the exhaust. I’ve read alot of info on the job itself and I’m pretty confident on doing the job myself just wanna make sure I’m using the right equipment. Thanks guys. Btw boat is 2005 23’ genesis extreme walk thru 496 mag bravo one
Dentdude1 06-25-2024 09:11 PM
Idk why but it’s not letting me post pics. Says I can’t until I reach 10 post 🤷🏻‍♂️
bencini231 06-25-2024 10:21 PM
You will be fine just changing tips, but I would probably have the external flappers on them or have an internal flapper on the tips. I did a search to see a image of that boat and in some of the pics it looks as if the exhaust is really low on the transom. Without seeing the exhaust in the engine bay I would at least recommend the external flappers and if you want to dress up the flappers on the tips, I would suggest the Hardin Marine SS flappers.
Dentdude1 06-25-2024 10:31 PM
Current tips have rubber flaps. Been looking at Eddie marine with internal flaps. Would that work you think? Tried posting pics but won’t let me 🤷🏻‍♂️
CheckmateScarab 06-26-2024 02:41 PM
I went the opposite direction on mine. Had internal flappers but wanted quieter so installed tips with muffler in them. I think they look a bit better than the clamp on style but then I had to go and install external flappers on the new tips anyway! I think as long as you have flappers one way or another you will be good
On a similar note, do turndowns need flappers?
Dentdude1 06-26-2024 05:21 PM
I’m thinking about installing Eddie marine straight ss tips with internal flappers. Tried posting pics but won’t let me yet lol
CheckmateScarab 06-26-2024 07:56 PM
If you're fine with angled tips I have a pair of Eddie marine 4" part #100-80 (with internal flappers) I'll let go for $100+shipping
patmckemy 07-02-2024 06:19 AM
Internal flappers are the way to go. Good luck!
Dentdude1 07-02-2024 07:55 AM
I ordered straight tips with internal flappers by corsa. Wanted the straight tips because I can always add a muffler at a later date if I decide but I can always run a pair of the rubber flappers too for added protection. My tips are mounted very low, even with bottom of transom so need all the protection I can get. Thanks guys
CheckmateScarab 07-02-2024 04:41 PM
Those will serve you well, I also switched to straight tips for external flappers hope they treat you well
