-   -   oil cooler thermostat setup (https://www.offshoreonly.com/forums/do-yourself-boating-budget/383001-oil-cooler-thermostat-setup.html)
Zinger 07-06-2024 06:34 AM
Hello,
I have a Gen 6 540 and looking to install a completed oil cooling system. I'm starting from scratch; I need everything including remote oil filter and hoses. I'm looking to see different set-ups that everyone is running.
Jeff
JaniH 07-06-2024 03:50 PM
This is what i use, not a remote filter system but clean and simple. 190f built in thermostat. https://3cgarage.com/products/thermo...ig-block-chevy
im MartinB 07-06-2024 10:50 PM
I'd suggest spending some time researching what the experts say when it comes to oil temps, and base your final system on that information. There's a lot of misconceptions especially in the marine world. If you start running a big engine in a boat and don't allow some temp to accumulate in the oil after a short period of time the oil doesn't look or smell right. I installed big coolers and then after my oil never got warm enough I added the T-stats off Hardin's site. Short version is I have 2 big coolers and 2 T-stats in boxes and don't really worry about oil temps in the mid 200s. I do however only run Brad Penn oil.
87MirageIntruder 07-08-2024 09:46 AM
I run an improved racing thermostatic filter base with 12AN hoses. The t-stats can be changed in a couple minutes without a mess to dial in your desired temp. I've got this running with a Hardin 13 plate box cooler on a 800hp whipple supercharged 500ci engine.
https://cimg2.ibsrv.net/gimg/www.off...c66ce2c3e8.jpg
