anybody recognize this kind of ignition amplifier box?? >
Old 10-05-2024 | 09:23 PM
phughes69's Avatar
Default anybody recognize this kind of ignition amplifier box??
This ignition amplifier box is on a boat Im working on. I has no decals or markings on it, no external connections other than the hole where the wires are coming out. The coil that is on ther engine is a Nutek Sizzler Firepower. I am figuring the box is too but all internet searches point to a box with external connections similar to a MSD 6A and this has none on the outside.
top and front of the box
Side
Bottom of the box
Other side
Ignition coil
phughes69 is offline
Old 10-06-2024 | 08:56 AM
mrv8outboard's Avatar
coolrunning racing
That is a Mercrusier Hi Performance ignition module. They did not use them for very long. They did not like moisture at all.
mrv8outboard is offline
Old 10-06-2024 | 10:14 AM
phughes69's Avatar
what do you know about them? Did they have a adjustable timing curve? Are there any adjustments inside the box?
Old 10-07-2024 | 07:07 PM
phughes69's Avatar
Bam , articfriends , do either of you recognize this type of ignition box. It seems to work with the T-bolt hall effect sensor and from what I have read not many of them do.
