-   Donzi (https://www.offshoreonly.com/forums/donzi-34/)
-   -   Best Prop for 35ZR (https://www.offshoreonly.com/forums/donzi/142384-best-prop-35zr.html)
Donzi35ZR 10-09-2006 08:19 PM
Best Prop for 35ZR
Has any one try different props for 35ZR with 496HOs? If so any good results? Stock props are Bravo1, 28P. I am thinking about changing to Bravo1 30P labed. Hope to pick up a coupe of MPH.
Shanghied Again 10-10-2006 10:00 AM
Re: Best Prop for 35ZR
I would try a 30 lab and if that doesn't work shave her to a 29, you are not going to gain much your boat should be running 82-84 mph and thats pretty respectable with 496s
Donzi35ZR 10-10-2006 06:52 PM
I will try that. Thank you.
throttleup 10-16-2006 09:54 AM
We are planning on doing some testing with Donzi on the 35 and 38 ZR's with our CNC props. The Donzi hulls should be perfect candidates for our CNC props. If you happen to live anywhere near the Gulf coast of FL we would be available to do some testing with you if you may be interested. Just give us a call.
