-   Donzi (https://www.offshoreonly.com/forums/donzi-34/)
-   -   COG on 35ZR (https://www.offshoreonly.com/forums/donzi/148744-cog-35zr.html)
pirata 01-08-2007 01:21 PM
COG on 35ZR
Going to be taking delivery of the new boat in a month or two. Wondering if anyone might know where the center of gravity on the boat is. Trying to figure out exactly where the boat should sit on my elevator lift. The lift has 2 forks 10 feet apart, so the center of gravity sits right in the middle determing how much stern/bow overhangs on each end. Thanks for your help.
ER
ericaull 02-04-2007 10:17 AM
Re: COG on 35ZR
CG is usually at the helm station......Donzi should be able to send you a hull diagram with dimensions for bunk placement, and CG station....I have a FORMULA and they sent me a diagram so I could set up my lift.:drink:
Donzi38ZXXX 02-04-2007 11:10 AM
Re: COG on 35ZR
I called Donzi and they faxed a diagram with all the hull dimensions and center of gravity measurements from the transom. The COG for my 38ZX is 153" form the transom.
