High HP 27ZR
Will this little boat handle, say 700-800 HP:evilb:
Anybody got any info? |
Somebody has GOT do do it!:party-smiley-004:
I just got back from a 90 mph ride in my 26ZX. I am thinking that the ZR would be a blast |
It's an option for a 525 from the factory. If you got that option I believe it came with True Kplanes. I think 6's or very low 7's would be the biggest you would probably really want to run in it. The 525 should have the boat @ about high 70's to very low 80's, so I would think with a 600 is hp you would be in the high 80's & with more you get the picture. I dont know to be honest exactly what you would encounter with the power that you are asking about as I dont believe it has been done to date. I also cant tell you for certain how many are out there with 525's as the main power was & is a 496 mag Ho that usually has them running 68-72 mph in most waters.. :)
Hope that helps you.. ;) Jamie |
Hey Jamie how havew you been I havent heard from you in awhile??
Just asking because I love the sound of big HP...
If the 26zx will handle it, why shouldn't the ZR? |
Originally Posted by LAKESIDE RESTORATIONS
(Post 2719182)
Originally Posted by Shanghied Again
(Post 2719323)
Hi Jamie, I have sold a few 27ZRs the 496/HO will run 72mph the 525 runs 80-81 mph and If I owned on I would throw a big motor engine in her the hull is a little more stable then the 26ZX, lower to the water and Kevlar hull, Donzi will most likely want you to sign waivers. The K-Planes would have to be changed to the larger Planes and I would go with a Stand off box. I could see the 27ZR hitting the Triple Digits mark.
Originally Posted by cmbracer
(Post 2719296)
Originally Posted by WMF
(Post 2719291)
Hopefully you are doing well too :) Jamie |
(Post 2719296)
| All times are GMT -5. The time now is 12:40 PM. |
