27zr vs 28 zx
I'm back in the market for a smaller boat, and looking for something fun. I've found a few donzi 28 zx's locally with some twin 350 mags, and twin scorpions, and debating on getting one and procharging the motors.
Basically looking for a boat that will run 85MPH to 90MPH+ when I want it to, but spend most of the day cruising at around 35MPH to 50MPH. I've also been looking at the 27ZR...and considering this option with a single big block, or even an ilmor since i'm seeing some of them for sale now on the net... Can anyone give me some guidance in which way to go??? I like hte ideas of the twins with prochargers, but a single ilmor in a 27 would be something different, can anyone think of how this would handle? |
All I can give you is some ZR advice. I bought mine in 2/07 & haven't regretted it for a minute. Fast, solid, efficient boat that we have really enjoyed.
I had the same decision to make as you but ultimately went the single route because I wanted the updated design of the ZR & the lower operating cost. Mine is bone stock still with a 496 HO. It would run 72 with the 4 blade but I did some swapping & settled with a labbed Maximus 27 to get better cruise since that was my ultimate goal. Cost me a couple mph up top but the boat cruises 50 right at peak torque of 3650-3700. We spend 80-90% of our time there so that was most important. My long term plan is a Raylar 525 kit to get me up to near 80 & call it good but I'm really happy with the way the boat performs as is. Good luck with your search. They are both great boats! J |
The ZX is a bigger boat with more headroom and twins. The ZR is low slung and smaller. Neither are going to hit 85mph without lots of money dumper into them. Id be looking for something else if that speed was my goal....something that already can go that fast.
I'm kind of limited with size, and either a 27 or 28 will be able to sit in my garage. I guess I don't NEED 90mph, but 80 or 85 would suffice... I don't mind having a bit of a project boat..
I guess running on lakes, and the st lawrence river, with the odd run out onto lake ontario is the type of boating I do...anyone have any recommendations?? Will I get the same top end out of either the zr or the zx? If so, I'm assuming the ZR will be less gas to operate it, less maintenance bills, and when I blow something up, I'll just have to fix one instead of 2 motors right??? |
Originally Posted by joejohn
(Post 2949432)
I guess running on lakes, and the st lawrence river, with the odd run out onto lake ontario is the type of boating I do...anyone have any recommendations?? Will I get the same top end out of either the zr or the zx? If so, I'm assuming the ZR will be less gas to operate it, less maintenance bills, and when I blow something up, I'll just have to fix one instead of 2 motors right??? Single vs twins? The debate can go on. You will be easier on the drives with twins. If you want 85 and can handle a smaller boat then a ZR with a 525 should be close. The 27 will be easier to work on since the compartment has more room. |
I'd go with the Ilmor just for the WOW factor :)
Oh, & we have over-nighted on my 27ZR several times w/o issue. That being said, it's not a cabin cruiser. If you want to go down there & hang out all day, neither one of these is probably the right answer. On the other hand, if you want a cabin that is used mainly for day storage & the occasional stay on the water, the 27ZR works fine.
J |
joejohn, are you only wanting donzi? used or new?
so far its just been the donzi's that i've seen that I like..sleek, simple design, they just look sharp, and fit my requirements...i also want a bit of a project boat that I can keep playing with, tweaking over a few years...hence why I'm not afraid of pro/whipple chargers...
(Post 2950225)
Either of these projects would be cool. I like the ZR idea because nobody has put big power in one yet. It would be a runner. |
27 ZR all the way, love that boat!!!
4 Attachment(s)
(Post 2947745)
Basically looking for a boat that will run 85MPH to 90MPH+ when I want it to, but spend most of the day cruising at around 35MPH to 50MPH. I've also been looking at the 27ZR...and considering this option with a single big block, or even an ilmor since i'm seeing some of them for sale now on the net... Can anyone give me some guidance in which way to go??? I like hte ideas of the twins with prochargers, but a single ilmor in a 27 would be something different, can anyone think of how this would handle? Cant speak for the boat, but I can for the Ilmor. Ilmor 710= AWESOME I have an Ilmor 710 in a 28 footer and its a simply an incredible mill. You will likely have a similar performance envelope as I do if you go with either rig. I got tired of all the air pushing BS (blowers/ prochargers etc) after lifetime of cleaning belt dust and blown engines decided to move away from all that to what worked for me before- a NA/ fuel injected marinized big bloc made with great parts assembled correctly by people that know WTF they are doing. I also dont want to deal with a twin engine boat for a variety of reasons, but still want to rock hard. I got 90mph on a cold morning and it gets 2.2 to 2.4 MPG on 300 mile trips. It idles like a kitten screams like a banshee. You will not be disappointed. Uncle Dave |
27ZR w/525. That should get you in the 80s. I don't believe the Ilmor is offered from the factory.
The biggest engine I have heard of in a 27zr from the factory is a 600.
Originally Posted by Donzi Andy
(Post 2958320)
Joe, it was good talking with you the other day. We look forward to working with you once you have picked your new ride.. :) Jamie / Lakeside
Originally Posted by thirdchildhood
(Post 2958308)
Good luck Joe! UD |
| All times are GMT -5. The time now is 01:49 AM. |
