-   Donzi (https://www.offshoreonly.com/forums/donzi-34/)
-   -   28zx on a hydrohoist (https://www.offshoreonly.com/forums/donzi/219344-28zx-hydrohoist.html)
akubi 10-30-2009 06:08 PM
I have a 2001 28zx to go on a 10,000lb hydrohoist. Does any have any tips for setting up the hoist for balance and step hull. Also i would like to know if you have to lift the legs or do the tubes sink low enough to clear ?
Thanks,
Randy
ZXXX Donzi 11-02-2009 05:02 PM
Thanks,
Randy
I did not have to lift the legs. I did lay on some steps using 2"x6" (or whatever the width required). The steps turned out perfect.
Out There 11-02-2009 06:16 PM
Had one on a 7000lb Hydrohoist. As Zxxx said double the 2x6 and carpet it and it will be perfect. Just measure from the step to the tramsom and you have your length.
Greg
akubi 11-03-2009 08:18 PM
Thanks for the info.
Randy
