NXT Lower End Blown Apart
2 Attachment(s)
Ran our 43 ZR with triple 700s for the first time. Didnt even run it WOT yet. Running about 4,000rpm @88mph and center drive did this. Not sure what caused it but we were trying to have boat ready for Cumberland Poker run. What the quickest easiest place to buy a new NXT outdrive and MR prop. This is our first triple engine boat. The port and center drive had same prop rotation and stbd opposite. Are all props the same pitch? Need a prop and drive asap
Did you impact anything? Any marks on the lower around the breakage area?
We were running in 25ft of water. No way we could have hit anything, I would think we would have felt it at high speeds if we did. No marks on other skegs or this one aside from the visible damage
http://www.bammarine.com/ Talk to Marc.
http://www.outdrives.com/ Talk to Pat. http://www.dolleroffshore.com/ Talk to Mindi. Or check with the Eliminator dealer there in Indy. Or you could launch a call up to the Formula plant and see if they have one there they would sell you. |
Double R Performance
looks like all you need is a lower? post this in general section.. should be some of them around..
| All times are GMT -5. The time now is 05:28 PM. |
