-   Donzi (https://www.offshoreonly.com/forums/donzi-34/)
-   -   38ZR questions (https://www.offshoreonly.com/forums/donzi/249713-38zr-questions.html)
mlb75 03-20-2011 12:14 PM
38ZR questions
I'm currently looking into getting either a new Spectre 32' outboard cat or a newish 38ZR and was interested in getting others opinions on both as well as some info on what to expect out of the Donzi.
If I go the Donzi route the boat I'm looking at has 525's with ITS XR drives. From what I'm gathering cruise speed is ~70-72 and top speed is realistically 89 with 90-92 being possible with me only in the boat and running on fumes. Is that correct? Also VERY curious about fuel burn at those speeds. That is one of the things that makes the cat look good, from everything I'm seeing it would cruise at 80 getting just shy of 3mpg doing it and top out at ~106 burning 50 GPH . How much worse is the 38 going to be.
What are the average life spans on both the motors and drives and any idea of ballpark costs to rebuild / maintain them? My impression is the motors and drives should be relatively reliable as long as I don't try to get much more out of the motors but what should I be ready to do to each on a regular basis to keep them up?
I know the ZR should handle rough water but how susceptible is it to spider cracks and are there any other things I should look out for or make sure to check on any boat I look at?
I live the the Virginia Beach area so will be doing most of my boating on the Chesapeake Bay and those areas but will be around the VB oceanfront area as well so are there conditions that I should avoid or are either boat big enough to not really care about a decent swell? How is the ZR going to do compared to the cat at taking seas at the quarters or beam or should that be avoided in both? I'm sure there will be a couple more questions and I really appreciate all responses. I'll be making my decision REALLY soon so that I will be ready to go with either before the season really starts here.
Either way I go I look forward to meeting as many people as possible from the boards this summer.
TIA
Sydwayz 03-20-2011 02:58 PM
edited for content
mlb75 03-20-2011 03:29 PM
Thanks for the reply, it looks like a nice boat but to be honest would rather not buy one that has been local, it'll forever be x's old boat...
Really interested in the fuel consumption on that motor combo though, any idea? Also recommended service requirements and longevity.
MarkDonzi 03-21-2011 06:35 PM
38ZR is a great boat, handles rough water pretty good, especially swells. The 525 is a good motor as long as your headers don't leak. make sure to have them checked out closely. Have them pressure tested for leaks if you can. They can cause lots of headaches. I never paid much attention to fuel consumption, you will burn a bunch! 525 should be good with routine maintenance for about 350-400 hrs then a top end rebuild will cost about $5k. Did my 600's last year.
Good Luck, hope this helps.
Sydwayz 03-21-2011 11:54 PM
Fair enough. I didn't notice this was in the Donzi section when I posted. The boat belongs to a good friend who wants to move to a CC. (I've got nothing to do with it's sale.)
Good luck with your search!!
Fuel consumption? Pfft!! What a depressing topic.
525s? Change the oil every 25 hours, open/inspect the drives once a season, and rotate them at that time; and go boating! They should run for 500 hours or more. (There's more to it than that, but they are pretty awesome powerplants.)
MarkDonzi 03-22-2011 08:38 PM
Hey Sydwayz, FYI
I tried swapping my XR drives last year and promptly wrecked both of them. Drive tech explained why, Driven gear is worn from driving forward gear for ??? hours, switching the drives now puts your worn driven gear up against your previous reverse gear which is not worn. This is bad news. Switching the drives only works if you do it every couple hours like the race boats do, otherwise starts problems.
Maybe you had better luck than I did!)
GK 03-22-2011 09:49 PM
I'm a former Donzi 38ZR 525 owner... Awesome boat. Expect 88-89 mph if propped correctly in freshwater. My boat was 2 yrs old and I replaced a leaking header and blew one XR drive.
Now a cat owner and it's a different world. Cruise effortlessly at 100 mph and top end is amazing. It would be difficult to go back to a V hull.
mlb75 03-25-2011 08:10 AM
Thanks for the input I think I'm going to go the cat route. The Donzi is a great boat and it was a close decision but the speed and operating costs of the outboard cat just look to good.
GK 03-25-2011 06:51 PM
That a boy!
Tom A. 03-26-2011 11:37 AM
Cats are great but I am a V man. I like the deeper cockpit and more planted feel of a V. Yes it is slower but for me better all around. It is hard to compare a 38Zr to a 32 Cat. There have been many a rough day where I walked past a 32 cat at 80mph. A bigger cat is a different story and will always be faster. Also, think about if you plan on trailering with it. Wide load permits and such.
mlb75 03-28-2011 03:15 PM
Tom, I hear ya and agree both are great boats, the thing that really has me convinced to try the cat for now is with it I can go with outboards and get both speed and economy. I really don't care about the cabin and as for trailering the one I'm getting has a 9' beam so I'm good to go unless I decide later on to step up to a bigger / wider boat. At that point I'd also be getting away from outboards and the equation would have to be looked at again. As for rough water handling if a larger V hull runs past me on a rough day, cool, I'll try and get pictures for the owner but I think it's gonna have to be pretty rough for that to happen unless we're talking about a significantly larger V hull. From everything I'm hearing the 32 cat will handle about anything a standard 38 V will (a competition version is another animal I'm sure). Maybe I'm wrong but to be honest I don't care, if it's that rough we'll go somewhere it isn't and have more fun.
BTW I'm truly not trying to troll the Donzi thread and talk up the cat, I posted here in an honest request for data on the 38 ZR since my decision was between it and the 32 cat. It's just after I got quite a few opinions I've decided the IO route isn't for me right now. The boating season here is too short to worry about how I drive the boat in fear of hurting either the motor or outdrive all the while getting admittedly dismal fuel economy. With the outboards I can run them at 90% all day long and they don't care, try that with an IO and I'm not convinced it's going to hold up for a season much less 2 or more. I know it's all a part of the cost to play but for now I'm going to try the outboard cat.
GK 03-28-2011 08:59 PM
Remember, it's addicting. Within five years you will have a Nor-Tech, Skater, or MTI. I wish you the best with your cat, you will be surprised on how well it handles rough water. If you get on top of the waves the ride is better than a V hull. If I could justify two boats my second choice would be a Donzi 38/43ZR. I like them both.
