Propp 38ZR
What propp size do you use on a 2006 Donzi 38ZR with 525 's ?
And what kind of speed should I expect? Thanks Hawkan |
If the hull is similar to the 2008 and the drives the same ratios and heights, I can give you my experience.
I run Maximus 5 blade Mercury props. they are shortened and labbed more than the already shortened and labbed props you buy direct from Merc. I get 88MPH at 5100 RPM. |
| All times are GMT -5. The time now is 07:46 PM. |
