2009 35' 2x496/425 how fast?
Nice one for sale just curious!
I'm trying to remember, I think like the 79-82mph range. somebody else can confirm, but that rings a bell.
tom |
If you cheat - low on fuel, no extra weight, ( I mean none), going with the wind, going with the current, and going with the tide - I got 83.3 GPS with tattle tale to prove it. Now, on a normal day, with all bets off, you'll be lucky to see 79. 4 Typically, you'll see 78.5 In bad conditions, you can sometimes only see 76.6. Some in this hobby think choppie water helps, but I have found that the smoother the water the better speeds. Hope that helps.
Originally Posted by RumBlur
(Post 3795041)
I have a 33zx with 500 hp efi's and I could only get 80,82 out of her. So would think slower then that for a 35 with 496s.
Originally Posted by 1989mach1
(Post 3818730)
I think the 35 is in the neighborhood of 1000+ pounds lighter. I think the 009 edition is even lighter than that, they have a different cabin that is lighter... the 009's are supposed to run 83-ish with stock 425's |
Will run 77-78 all day. Best I have ever seen is 79.5.
| All times are GMT -5. The time now is 05:45 AM. |
