2 Attachment(s)
[ATTACH=CONFIG]506995[/ATTACH][ATTACH=CONFIG]506996[/ATTACH]
We had the crappy factory molded ones removed and added Livorsi LED lights. Still looking for a good replacement transom LED light (entire unit, not just a bulb). Anyone have any suggestions? It doesn't seem to be any standard marine size. |
Nice work PremierPower!!! I changed just the bulb in my transome light. Again, www.superbrightleds.com be sure to order just the std (shortie) or your lens will not go back on. I have nice bright rear lighting now.
U
Originally Posted by RumBlur
(Post 3949787)
OK, here is what I learned: go to www.superbrightleds.com and order:
1142-x45-T: 1142 LED Bulb - Single Intensity Dual Contact 45 SMD LED Tower 1142-G45-T: 1142 Green $24.95 1142-x45-T: 1142 LED Bulb - Single Intensity Dual Contact 45 SMD LED Tower 1142-R45-T: 1142 Red $24.95 They fit perfect, and my oh my, what great light. I am going back to see what they have to brighten my rear / transom light which currently sucks. After further study, it's almost like Donzi installed the housings up-side down. In other words, the bulb is in the bottom of the housing, shinning "up". (good only if helicopters might hit you) Where as, it would work way better (be seen) if it were mounted in the top of the housing, shinning "out". (where the other boats are - duh) OK, problem solved - for now. The are wonderful 3pointstar |
1 Attachment(s)
For thise interested in changing out the transom light to LED, we ended up getting this transom light and it worked perfect. Painted it black and even had our name cover it where needed.
Led Stern Light -Stainless Steel Transom for Boats Navigation-five Oceans https://www.amazon.com/dp/B00D35VMEW..._fl8-tb1C9G5J0 [ATTACH=CONFIG]528331[/ATTACH] |
1 Attachment(s)
Here it is before the name went on
[ATTACH=CONFIG]528332[/ATTACH] |
Originally Posted by 3pointstar
(Post 4177515)
U
I've used the leds from superbright The are wonderful 3pointstar |
Originally Posted by PremierPOWER
(Post 4177655)
[ATTACH=CONFIG]528332[/ATTACH] Wow!! Just plain Wow!! (the drives and props) |
| All times are GMT -5. The time now is 01:48 AM. |
