zr27 trim
was hoping someone could give me the distance in inches of the ram at full up on the throttle switch as well as full up on the trailer switch. had to replace senders and need a base line thanks
Full up is when the drive stops. The trim limit is sometimes different depending on the hull and drive height. Most standard setting are 6 inches from the end of the ram to the center of the pin that holds it to the drive.
thanks for your info katanna...........was hoping someone with a zr27 could tell me factory distance on the throttle switch full up and full down.not many of these boats around
| All times are GMT -5. The time now is 08:41 PM. |
