-   Donzi (https://www.offshoreonly.com/forums/donzi-34/)
-   -   28 ZX hatch actuator problems (https://www.offshoreonly.com/forums/donzi/299713-28-zx-hatch-actuator-problems.html)
Alladin 07-25-2013 07:22 AM
Originally Posted by Donzi Dude (Post 3964775)
Have you checked your voltage to it?
It's just a dc motor.
The voltage out at the Cables is 12 volts plus, but I presume it will fall when the actuator is under load. So I'm gone try shore Power and see if its any different, maybe the batteries are just bad, although there is no problem with starting the Engines and so. Also I have same problem with opening the hatch with Engines running.
atisvt99 08-27-2015 09:35 AM
The hatch motor in my 28zx is doing the same thing... what did you ever find out about this issue? Resolution? :)
Thanks!
atisvt99 08-27-2015 09:41 AM
Originally Posted by jvthundercat (Post 3963314)
Get ahold of Danny at Acculift, he will fix you right up and it's cheap compared to buying a new one. The seal on the end of the shaft over time needs to be reamed out as it gets too tight and drags on the motor, then you need a new motor.
Any idea how to get ahold of Danny? I cant find any phone numbers for Acculift anymore... thanks much!
