Hatch Actuator
hi Guys,
05, 38ZR and my hatch will not open. I just recently found the wiring schematic for the "Ultraflex" actuator used on the boat. I am going to check the switch on the dash panel first. Anybody else run into this problem? If so were you able to manually open the hatch? Has anyone seen where Donzi mounted the relays for the rams? Any help would be appreciated! Thanks, Mark |
that i dont know, but if your going out to the marina this weekend i could give you a hand..
Originally Posted by prostock3
(Post 3996513)
Got lucky, Wire came loose from the switch. Hatch works fine now!)
| All times are GMT -5. The time now is 10:00 AM. |
