-   Donzi (https://www.offshoreonly.com/forums/donzi-34/)
-   -   33ZX getting up on plane (https://www.offshoreonly.com/forums/donzi/311521-33zx-getting-up-plane.html)
Tinkerer 04-05-2015 09:04 AM
If you are not demanding the best top speed then go to Bravo 4 blade props and You WILL be real happy with how it gets on plane. My 34 SCARAB used to be very problematic getting on plane. There is a video on here of it blowing out and me back pedaling.
I went to 4 blades and then you could pull up skiers. (used to do this on a regular basis ) I then went to -2 IMCO shorties and my planning was a little more eventful. I would just roll into the throttle and hold it at 5000 RPM and it would just push up onto plane in about 3 to 5 seconds.
My Daytona is a different story. With the prop shaft 1 inch ABOVE the bottom of the hull I have to do the same 5000 RPM but it takes 5 to 10 seconds to push over until it hooks up. I am actually going back 12 inches and up another inch before it goes on the water this summer. It is real easy for me to go down but as always very difficult to go up. I am running a -3 IMCO shorty now. I have a -2 IMCO lower also.
One big change I made was increasing the negative trim range of my drives. I shortened the trim rams 3/4 inch and with a little careful grinding ( in areas that DONT effect the strength of the gimbal ) I was able to get a lot more negative trim and that greatly improves the props ability to push the boat onto plane. Shortening the trim rams is a very easy job. Any engine shop should be able to do this. ( they do need a lathe with a 3 inch head. )
donzi33zx 04-05-2015 05:55 PM
I'm running 28p bravo 4 blade props.
1989mach1 04-05-2015 06:38 PM
That is what I am spinning as well. Looking to have them labed next winter.
donzi33zx 04-06-2015 06:10 PM
I tried a labbed set, no real performance difference, the 30 bravos lowered rpm touch but raised top end and had nice acceleration
donzi33zx 04-06-2015 06:12 PM
Originally Posted by 1989mach1 (Post 4287931)
From tge bottom of the rub rail to center of prop shaft I got 48" with the drives in neutral position whisper my boat is on number 2 on the gauge. not all the way tucked in
My measurement to same points was 45, so a consistant 3". Higher than others
1989mach1 04-06-2015 06:34 PM
Thats a bit higher. Maybe u have shorter lowers I was thinking about geting shorties but someone told me save your money.
1989mach1 04-07-2015 05:52 PM
He sead the gain if any is not worth the coin. ....
Donzistyle 06-05-2015 04:41 PM
Has anyone get a 33 ZX over the 92mph? Mine jumps right at 90 and i cant eliminate that, so you have to push back the throttles... Tried several props Maximus and 4 Baldes...
I have -2" Stelling Boxes with XR and -2 Sc Lower and my X Dimension is 4,5" right from the bottom of the boat (where the drive is) to the propshaft...
Has anyone experience with that or an idea?? Thanks for your help!
1989mach1 06-17-2015 07:58 PM
Have you tried to run it with the tabs around 3 at that speed? With the tabs around neutral or a little down that extends your running surface and stops the hopping.
