-   Donzi (https://www.offshoreonly.com/forums/donzi-34/)
-   -   Donzi 18 Classic Questions (https://www.offshoreonly.com/forums/donzi/364129-donzi-18-classic-questions.html)
Stuckonstupid 12-06-2019 05:01 PM
I have recently purchased a 1974 18 classic and have some questions that I didn’t find answers to using the search feature.
where can I get a throttle/shifter for a left hand drive?
it has a mercruiser 350 and Volvo drive, the power trim (lift) doesn’t work and the motor appears to be toast, where can I get this part?
would there be any benefit to swapping the Volvo drive for a bravo?
thanks for any answers/help.
dhcomp 12-07-2019 03:22 PM
Search for parts based on the Volvo drive, not donzi. Any marine parts place should be able to sell you a throttle shifter and trim pump.
madbouyz 12-07-2019 03:36 PM
Yeah , shouldn't be too hard to source a replacement for that 'trim' or is it really just the tilt motor ? Is your outdrive a 270 or a 280 OR a 270T or a 280T ?
As for changing over to a Bravo ... it isn't going to be cheap and your transom is going to have to be re-sealed and cut for a B unit , plus the motor will more than likely have to be shifted as well. At this point your transom might be in need of a total re-build anyway on that vintage but the big question is , what condition is the fuel tank in ?
A new Bravo transom and drive is going to be a fair bit heavier than the existing Volvo and you can see that in that most of the C 18s had Alpha units once Donzi began converting over to 'black' , even up to almost present day.
If your steering is on the port side you'll have to counter-rotate the Bravo unit as well. The old 270 and 280 Volvo drives were bullet proof although not quite as hydrodynamic as the Alpha units so there's always a trade off somewhere.
Most Donzis of that vintage were very pretty due to color options . Post a pic or 2 !
Stuckonstupid 12-07-2019 05:51 PM
https://cimg2.ibsrv.net/gimg/www.off...053f48fba.jpeg
Only reason I asked about the bravo change is I have a complete xr from gimbal to lower. It is a power tilt drive, no trim. The steering sucks but it eventually goes where I point it. I took it out today and it’s a blast, just need to clean her up a bit and enjoy it. The transom and stringers are solid as a rock and obvious that someone replaced both not too terribly long ago.
https://cimg4.ibsrv.net/gimg/www.off...c512180a8.jpeg
https://cimg9.ibsrv.net/gimg/www.off...5cc9cecba.jpeg
madbouyz 12-08-2019 06:58 AM
Hey , an X18 . Do you know they're faster than a regular C18 ? :D
The old cable steering Volvo system can get pretty sloppy over time. Maybe a new cable and tightening up a few things can help .
thirdchildhood 12-08-2019 07:33 AM
Not to steer you away from this site but you can find pretty much anything you want for these boats at donzi dot org.
Stuckonstupid 12-08-2019 10:35 AM
I have tried to register for that site 3 times with 0 success.
