1967 center console?
Was driving by a local shop/brokerage center by my house today and spotted a neat yellow center console with an I/O, as I drove closer, it appeared to be a Donzi!! I called the broker immediately and he informed me it's a 1967 Donzi, 20 foot cc . I have seen a lot of boats but I have never heard of such a thing, hoping someone here may have some information on this. Wondering if maybe its mislabeled as Donzi and is actually a different brand. Any information on this would be greatly appreciated. For the asking price, I will likely buy it if I do come to find out it is what it's advertised as, as i imagine this was a practically custom built boat, and low lpwnproduction. One neat feature I saw was the shifter handle was a wooden circle with a Donzi logo in the center of it. Any information people could give would be very much appreciated.
Originally Posted by PremierDetailer
(Post 4744421)
You won't find a hull number on transom as late model boats have but may find a Donzi ID tag if boat is still all original. Regardless, I would ask to see the title and be sure it documents the boat as a Donzi. Hope this helps!?! Jason @InshoreOff Basic Info: Lake George Donzi Classic Club: St. Tropez |
I've had mine since 1987. It was advertised as a '66 but might even be a '65. Supposedly they made a total of 117 of them .
I did a total deck off , floor tub out 4 year resto that was completed in 2006-2007 and you might say I'm pretty familiar with them and their weak spots . Even if this boat checks out structurally the big worry is the fuel tank. I've followed every thread on the St Tropez' that I can find and some had only one tank but mine had 2 and you have to cut the boat up (or dismantle it ) to do one of those tanks. Mine had absolutely no HIN anywhere . Built well before the mandatory number on the transom was required it still had no wax pen numbers or a foil tag anywhere. What is the one that you saw powered with ? edit to add .. The Lake George Donzi club info states production as 102 units but I got the 117 number from a thread on the Donzi.net a few years back when the topic came up that a member had found what was supposedly the very last St Tropez built and it was for sale.then . Previous to that I had always gone with the approx 102 boats. |
Originally Posted by madbouyz
(Post 4744496)
Volvo outdrive = Good .
Mine had obviously been repowered a few times before I got it but when it arrived it was an older Merc drive with a Ford 351 4bbl and center riser manifolds , probably a reasonable 225 hp at crankshaft. The subject of tanks is a bit of a puzzle for me . The St T brochure states 42gal fuel capacity but the boats that I've seen with the single tank under the console can't possibly be 42 gallons because they would then extend into the lazarette under the floor in front of the console , and they didn't. I have the tank under the console (20 gal approx new build) and the fwd tank is under the forward storage lazarette in the bow (22 gal approx new built also) The forward tank was original when I got mine and was leaking badly so for a number of years I relied on the tank under the console which had been recently replaced just before I got the boat. . I would imagine that the replaced bulkhead you're talking about is the one at the front of the lazarette under the floor and it (in my case) delineated the fwd fuel tank from the storage area. It too had long turned to sponge as it was right up against the foam that locked the fwd tank in place. Actually , all of the bulkheads in the St T are of pretty minimal construction. If someone DID replace that bulkhead because they changed out the forward tank and were able to do it without butchering the front of the deck seating area and floor they were not only very talented but very patient as well . . |
(Post 4744518)
When it comes to the fair value of used boats in your country I'm probably not the best person to ask. Maybe the seller should be reminded that it's a 53 year old boat that sold for about $4000 new :evilb:
I can sort of visualize that issue with the arch and the deck though. The deck in those areas is cored but only in the center areas , outside of that as you move towards the rub rail it goes back to single skin glass , and it aint that thick ! If yours is like mine they used what appeared to be a very good grade of ply in the construction of the stringers and transom . I don't know what it is but it has a very pink color compared to the wood used in the deck coring . When I removed my transom slug it was wet too but it wasn't in any way rotting. The limber holes in the aft of the stringers had only a few inches of rot around them as was typical , and still unfortunately mostly is , they weren't sealed up at all . Have you gotten in and walked around this thing ? Before I redid mine the cockpit flooring made all sorts of cracking noises and I found out the reason for that was when they layed the wood core in the mold it was just floating on resin saturated glass and there was huge air voids all over the place. Another issue was that the floor tub wasn't supported properly in the area of the console and the area just aft of it and over the years the cockpit floor on both sides of the console literally cracked right through .. about 18" per side ! Another common area they had problems with were on the hull bottom , the full length running strakes. Look underneath and go about 3' forward from the transom. In the right angle corners of the strakes I'll bet anything that you'll see cracked gelcoat (assuming the bottom isn't painted) . The full length strakes fall about 10" outside of the stringers and seeing it's a single skin hull the stresses of the water rushing up from the keel at planing speeds cause them to flex considerably. This isn't a problem with the lower half strakes as they mostly hit the stringer and they're nowhere near the water at planing speeds. I know of at least one other where this was NOT a cosmetic issue . In mine and the other water was weeping through on at least one side . If your willing to tackle improvements and work yourself this could be a great project at the right price . Any chance of maybe putting up a pic or two of it ? BTW , if you go over the the Donzi.net and enter the search words St Tropez a lot of stuff comes up. Unfortunately a few years ago there was a serious software problem and all pictures attached to posts prior to 2009 or so vanished . |
(Post 4744636)
I can sort of visualize that issue with the arch and the deck though. The deck in those areas is cored but only in the center areas , outside of that as you move towards the rub rail it goes back to single skin glass , and it aint that thick ! If yours is like mine they used what appeared to be a very good grade of ply in the construction of the stringers and transom . I don't know what it is but it has a very pink color compared to the wood used in the deck coring . When I removed my transom slug it was wet too but it wasn't in any way rotting. The limber holes in the aft of the stringers had only a few inches of rot around them as was typical , and still unfortunately mostly is , they weren't sealed up at all . Have you gotten in and walked around this thing ? Before I redid mine the cockpit flooring made all sorts of cracking noises and I found out the reason for that was when they layed the wood core in the mold it was just floating on resin saturated glass and there was huge air voids all over the place. Another issue was that the floor tub wasn't supported properly in the area of the console and the area just aft of it and over the years the cockpit floor on both sides of the console literally cracked right through .. about 18" per side ! Another common area they had problems with were on the hull bottom , the full length running strakes. Look underneath and go about 3' forward from the transom. In the right angle corners of the strakes I'll bet anything that you'll see cracked gelcoat (assuming the bottom isn't painted) . The full length strakes fall about 10" outside of the stringers and seeing it's a single skin hull the stresses of the water rushing up from the keel at planing speeds cause them to flex considerably. This isn't a problem with the lower half strakes as they mostly hit the stringer and they're nowhere near the water at planing speeds. I know of at least one other where this was NOT a cosmetic issue . In mine and the other water was weeping through on at least one side . If your willing to tackle improvements and work yourself this could be a great project at the right price . Any chance of maybe putting up a pic or two of it ? BTW , if you go over the the Donzi.net and enter the search words St Tropez a lot of stuff comes up. Unfortunately a few years ago there was a serious software problem and all pictures attached to posts prior to 2009 or so vanished . https://cimg3.ibsrv.net/gimg/www.off...3edf55d20.jpeg https://cimg9.ibsrv.net/gimg/www.off...3667370b1.jpeg https://cimg9.ibsrv.net/gimg/www.off...c66ea36e5.jpeg https://cimg3.ibsrv.net/gimg/www.off...c318ff431.jpeg |
Kewl ! Thanks for that , now I have something to look at .
There's something very familiar about that boat. I'm sure I've seen it somewhere before , maybe in reference to a sale a while back . Looks like it might have originally been a blue/white boat that's been resprayed . Someone obviously spent a fair amount on that shorty bow rail , arch and (horrible) console pipe frame . The St Ts only had a small grab rail on both sides of the console , no wind deflector or supporting frame. I can see a few other hardware changes as well but it's intact . I can see something on the cockpit floor on the stbd side of the console but it doesn't resemble the cracking/support issue I mentioned above. That shift knob is period correct and if it's the original one it's a miracle it's still there . Do you plan on having another look ? I'd recommend it if for nothing else but to look for that issue with the hull bottom I spoke of. IF the floor insert that the engine box sits on is not secured it's easy to pull it up and you can then see the inside of the hull areas that I was talking about . |
(Post 4744658)
Yep , all that piping work is custom . Mine has the original factory bow rail and it's nothing like that at all . It also still had the 2 tiny grab rails on either side of the console .
One of the deceiving things about the St T is its scale . When you're in the boat , especially when it's in the water it has a surprising amount of space for its size. But when you look at the boat from the outside when it has people on board it hits you that it's really pretty small . IMO all of that large pipe work that was done is out of scale to the rest of the boat . Look forward to your findings . It just occurred to me that if you have a 2 tank boat there should be a 3 way valve in the engine room , more than likely on the inside of the stbd stringer . |
5 Attachment(s)
For reference you may want to check out this ad that was sent to me by one of the guys on the Donzi.net (thanks Greg)
I'd say that all of the rails on this one were added after it left the factory too . Attachment 576742 I notice that the one for sale (above link) has a fuel tank vent on the port forward side of the hull (like mine does) , unfortunately the pics you posted only show the stbd side of the boat BUT both boats have what appears to be a sight glass port on the floor in front of the lazarette . To me that would possibly verify that both boats have a forward tank , so in yours there should be another one under the console. Also the 7th picture in this ad shows a rear view of the console and on the port side floor you can see what appears to be a crack in the area that I previously mentioned. |
| All times are GMT -5. The time now is 11:38 AM. |
