38zr interior
Has anybody ever replaced the engine hatch vinyl and had to remove the plexiglass cover on the inside? Looks like they siliconed it in and a pain to remove. Any ideas would be helpful. Thanks
does anyone know who made the donzi interiors? |
JLS ...
I came across this on one of the Donzi sites -- Premier Performance Interiors in Sarasota FL www.ppi-fl.com did a lot of the interiors when the ZXs and ZRs were built. FWIW, I have also come across info suggesting that some work was done in house as well. good luck! |
I actually just pulled my entire interior out. The plexiglass was kind of a pain but it came out, in pieces though. It was spray glued onto a type of fiberglass backer board which was then adhered to the hatch with some type of adhesive like a 3m 4200/5200 or some construction adhesive. I used a hammer and wonder bar to pry the plexi off slowly and worked my way from the front to the back. Crappy part is about half way back the fiber board starters coming with it so now I have to find a replacement for that as well.
Took it apart this weekend and found the same Issue, Was able to get Plexi off but backer board came off in little pieces. Did you ever figure what that backer board was exactly?
No I have not yet. Put her in storage for the winter and haven’t been back over yet.
Removed the vinyl and foam from the sun pad. I think I’d like to replace the black plastic base of the sun pad. Anyone know what that material is and where it can be bought?
| All times are GMT -5. The time now is 02:03 AM. |
