Go Back  Offshoreonly.com > Owners Forum > Donzi
33 ZX Fresh Water Winterizing >
Old 10-23-2020, 06:02 AM
8Ballclan's Avatar
Default 33 ZX Fresh Water Winterizing
When winterizing fresh water system is it best to just run the fresh water out via faucet, add then add pink stuff to tank/lines or is there a better way?
FWIW -- 1999 33 ZX with vacuflush
8Ballclan is offline
Old 10-25-2020, 12:34 PM
They sell a kit, but what you want to do is be sure the pink stuff is sucked all through the system, then spits out the exhaust. Then, you can remove any of the drain plugs, and then loosen and pull back the water pump hoses off the nipple. So, only fluid left is pink stuff in low elbows, etc.
imartin is offline
Old 10-26-2020, 07:14 AM
Quinlan's Avatar
If he is talking the fresh water -ie sink and chitter-
Drain hot water tank and then blow all lines out with compressed air is what we do. Pink stuff will stink up the system.
Someone told me run some Cheap Vodka thru system. Then No stinkie lol and just add Limes and Grapefruit juice in spring
Quinlan is offline
Old 11-02-2020, 06:54 AM
8Ballclan's Avatar
imartin -- yes, should have clarified better ... I was thinking about the sinks and head. I still have several gal of fresh water in the tank too. This is our first winter with the boat and unlike an RV there's no tank drain sticking out the bottom -- I was thinking someone may have come up with a clever way to purge the system rather than just turning on the faucet.
Quinlan -- cheap vodka - lol
Old 11-02-2020, 07:47 AM
Run the system until no water comes out, if you have a hot water tank drain and bypass it.
if you have a dockside water connection you can pump antifreeze in there, or blow out with air. If not add a gallon or 2 of the pink stuff to the fresh water tank and let that run through the faucets
Unlimited jd is offline
8Ballclan (11-11-2020)
Old 11-02-2020, 08:41 AM
21 and 42 footers
t500hps's Avatar
Um....did you read what the OP wrote at all?
t500hps is offline
Old 11-02-2020, 08:47 AM
Do NOT let the anti freeze in the water heater, it will stink and make nasty flavored water that you cannot get rid of until you replace water heater. Be sure to drain and bypass water heater.
Don't forget the fresh and waste tanks.
GLENAMY 242SS is offline
Old 11-10-2020, 09:28 AM
t500hps: No, I did not read what OP wrote at all. Of all the thousands of OSO posts out there, I ironically just replied to this one blindly. Ofcourse I read it, albeit maybe too quickly, sorry I was off the mark a tad, and obviously wasted your time for your reading it. That said, when we all are as perfect and crisp as you, the world will be a better place. Until then, be well. Be safe. Thanks.
imartin is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information -
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
