-   -   Hierarchal of Drives (https://www.offshoreonly.com/forums/drives-lower-units/157564-hierarchal-drives.html)
bert4332 05-06-2007 03:27 PM
Since I joined recently I've been noticing certain drives are limited in handling in HP. Is there a hierarchy of drives relating to performance?
thanx
RedDog382 05-06-2007 06:56 PM
Alpha
Bravo
Bravo X and XZ
Bravo XR
TRS (retired)
#3A (retired)
NXT
Arneson
klaw 05-06-2007 09:13 PM
how about
alpha ss
konrad
imco
Donzi38ZXXX 05-06-2007 09:34 PM
Originally Posted by RedDog382 (Post 2118554)
Alpha
Bravo
Bravo X and XZ
Bravo XR
TRS (retired)
#3A (retired)
NXT
Arneson
If the TRS drive is stronger than the Bravo XR - Why did they stop using it?
Old Ride 05-06-2007 09:57 PM
Going from the TRS to the Bravo you lose about 250 lbs, (smaller transom plate and no tranny) and the engine is about 18" further back towards the transom.
phragle 05-06-2007 11:23 PM
mc1's (pre-alphas), theres also mr's and alpha gen 2's in the mix
MrCIG 05-07-2007 12:24 PM
The Bravo was cheaper to build (no transmission) and weaker therefore they have built in reaccuring revenue. It's there marketing department runnnig there engineering department. LOL
Konrad should be right after NXT Drive
Mark:drink:
thedonz 05-07-2007 01:11 PM
add SSMIV and SSMV before #6
Shawn D 05-16-2007 10:18 PM
I am new here too. I've been running a 7.4 Merc - Bravo 1 - 230 PQ, and am looking to go to a bigger boat. Where do the Volvo's fall in to the above list. In particular the 415 DPX. It has the dual Props. Like the Bravo 3's, Which I don't see in the list either. Are they Tabu? HP hogs or something?
J-Bonz 05-16-2007 11:10 PM
OMC Stringer.................. :)
tblrklakemo 05-16-2007 11:34 PM
They should fall into the bravo 1 category. Nothing more or less. Look into the internals etc......for instance, bravo 1 with serial #'s beginning with OM are late model and contain some of the larger, soon-to-have-been, bravo X internals. Still not an X though.
