-   -   ??? on bravo xz drive (https://www.offshoreonly.com/forums/drives-lower-units/159736-bravo-xz-drive.html)
fastted 05-31-2007 10:58 PM
I have serial #'s off my drive it should be a xz thats what the guy told me when I bought my boat numbers are om137518. Is the prop shaft the same size on a bravo 1 as the xz?? Thanx for any help you can give me! :eek:
excursion 06-01-2007 07:00 AM
Yes, it is the same as Bravo 1 , you should have a larger universal joint and the spanner nut should look like the XR, has holes around instead of the teeth.
gsmith9898 06-01-2007 07:36 AM
no the prop shaft is NOT the same size as the bravo one. It is 1.25 inch shaft like the xr drive.
Mbam 06-01-2007 09:24 AM
Mercury shows that serial as a Bravo 3 X, so what you actually have would depend on the lower that is installed.
See:
http://www.go-fast.com/mercruiser_bravo_sterndrives.htm
fastted 06-01-2007 11:21 AM
See:
Thanx for all the help! I looked at the link you sent me and my drive has only one prop. Is a bravo 3x good?? I just put in 670hp n/a motor will tha drive hold up good?? Thanx
tblrklakemo 06-04-2007 05:30 PM
I would like to add that my boat is an 01' and my serial # starts with OM-114........02 couldnt have been the first yr for the beefed up B1.
