-   -   Volvo drive integrity question (https://www.offshoreonly.com/forums/drives-lower-units/160105-volvo-drive-integrity-question.html)
Keytime 06-05-2007 06:10 PM
I'm looking at a 1994 Wellcraft 29' Scarab with a Volvo drive unit (single big block). How do they compare to the Mercruisers? Are they something to avoid?
I appreciate the help. Shopping for my first "big" boat right now and doing my homework.
Thanks!
Keytime 06-07-2007 11:33 AM
Let me rephrase that... does anyone have a 502 Volvo/Penta engine/drive system with dual props in their boat? If so, how do you like the performance and reliability?
tblrklakemo 06-07-2007 11:59 AM
Ive heard they are quite strong drives. From what I recall they have few of the issues that plague bravo 1's. The duo-prop is a source of drag on the water at speed though. Might want to do a search for the combo on OSO and see what turns up. Somebody else will chime in soon.
260SX 06-07-2007 12:28 PM
I have a 260 Powerquest Legend e/w 496 Mag and a Volvo DPX drive--to date I have not had any problems with the drive. The boat has 150 hours on it and top speed is around 60mph.
Keytime 06-07-2007 04:13 PM
Does the dual prop set-up give better acceleration out of the hole?
onesickpantera 06-07-2007 04:47 PM
Yes. And the durability of the Volvo is much better than a Bravo IMO.
tblrklakemo 06-07-2007 08:29 PM
Yes, but you will loose some top end to drag i think. That is why a lot of ski boats and bigger cabin cruisers have them....gets things moving along.
Keytime 06-07-2007 11:25 PM
This is gonna sound dumb but I'm gonna ask it anyway, especially since I haven't seen a V-P duo prop up close.
Do you have the option of removing one prop? I'm assuming not.
AGGRAVATION28 06-08-2007 03:17 PM
Volvo says no. Also they do not suggest "mixing" prop sizes. Must be run as a set.
glassdave 06-08-2007 09:14 PM
There was actually some tests done with mixing props. Performance was increased quite a bit but the drive basically ate itself in the process. The DPX is a fantastic drive and is very durable. i would trade the Bravos of my Scarab in a heartbeat for a pair of DPX's. For a single screw boat its the only way to go. We have been racing them (hard) for several years now and i have yet to see one blow. i would not shy away from a boat with that drive on it thats for sure
