-   -   Changing prop rotation (https://www.offshoreonly.com/forums/drives-lower-units/160236-changing-prop-rotation.html)
Jim Diesel 06-06-2007 09:58 PM
My friend bought a 27 Profile with a Bravo 1 and it came with a left hand prop he is wanting to change it to a RH prop the local shops told him he had to change his upper gear set. I thought you just changed your shifting linkage to match direction.
What is the correct method to change to a RH prop?
ACTIVESHACK 06-06-2007 10:01 PM
Change the linkage. He can test the boat with the new prop by running it in reverse to make sure its what he wants to do.
tblrklakemo 06-06-2007 10:02 PM
Put an opposite prop on it and use it in reverse. Shouldnt be a problem. Or you could break open the drive and change stuff.
US1 Fountain 06-06-2007 10:59 PM
Nothing in the drive to change. It's done at the shifter.
t500hps 06-07-2007 05:40 AM
and I'd look for another prop shop too!!!
hoghead 06-07-2007 08:25 AM
What's the matter?....didn't believe me when I said to change the linkage?? I see how you are.....
Jim Diesel 06-07-2007 10:03 AM
Bite me :drink: he said two other shops told him that also im just checking before I tell him what can be done...
tblrklakemo 06-07-2007 10:07 AM
Ah....well that makes it easy. I bet you just flip the thing around?
dollerparts 06-07-2007 10:15 AM
just change the control box and prop
hoghead 06-07-2007 11:13 AM
what two other shops?
