-   -   Any advice on connecting an ITS shift cable... (https://www.offshoreonly.com/forums/drives-lower-units/162171-any-advice-connecting-its-shift-cable.html)
2112 06-28-2007 11:50 PM
To the latch inside the upper unit while putting the drive onto the gimbal assembly by yourself? The ITS shaft is so long that as I struggle to gently guide that in place, the latch, which I already pulled forward, seems to get pushed back very easily by the fully extended cable as I slide the drive on.
Thought someone may have a method to prevent this.
Cattitude 06-29-2007 07:52 AM
I've done my ITS a few times, do not recall any trouble, get it resting on the studs with 3/4" of daylight, move the shift lever where you want it and or use needlenose, goes ka-chunk and it's in.:D
John the Drive Man 06-29-2007 09:44 AM
It's suppose to do that. When you put the drive it shifts to neutral. Thats how you know it's on properly.
2112 06-29-2007 10:44 PM
yea, mine isn't going on that nice. The shaft slides in perfectly but something isn't happening on the clutch. I just can't see the cable and put the drive on at the same. I guess I need to get another set of hands.
