-   -   engine mount location (https://www.offshoreonly.com/forums/drives-lower-units/162921-engine-mount-location.html)
superwrench0166 07-09-2007 03:16 AM
any one have measurements on where to loacate the engine mounts on a alpha 1 gen 1. Distance to center from transom and side to tide with standard merc mounts.
SmallPP 08-07-2007 08:34 AM
It depends upon what engine you are using. I swapped a 4.3L to a 5.7L in my boat, and the mounts went forward 4". I think SBC and BBC are same location, but I am not sure.
If you are using a SBC, I could measure mine if it helps you.
My stringers were not full length, so I added stainless steel C channel to make them full length. Dropped the motor in, then drilled and bolted the mounts down to it.
You could also relocating plates from a Chevy S-10 V6 to V8 conversion kit if you wanted to make no changes. I decided to just use the channel.
