Gear Ratio- I'm confused??
I just disassemble my Bravo 1.... on another thread OSO members were convinced I had 1.36 gears (based on speed & RPM's). However on disassembly I found the pinion is 27 teeth & the drive gear set is 32 teeth. With a calculator this figures to a 1.18 to 1 ratio, but per a gear chart I saw a 27/32 is a 1.5 ratio......??? How can this be mathamatically??
Please explain! :( |
Originally Posted by blown formula
(Post 2196864)
No, this is just the upper housing pinion & gearset 27/32. The lower units on Bravo 1's I thought were all 1:1 ratio, but mine is slightly different from that.... about 1 1/8th turn on vert shaft to 1 turn of the prop..... what ratios are available in B1 lowers??? I'm running 1200 hp in this 31SS Sonic & am not turning but 23" props!! My Formula 312 turns 26" & 28's!! w/454 Mags. Gotta be the gear ratios.
I dont know.
The gears in the lower are 15 driver 19 driven tooth counts. I just counted the teeth on my old gears so I am 100% sure of the tooth count. That should work out but I didn't bother doing the math.
Rene |
Ok, that works out to lower drive ratio of 1.27 in the lower.
So, 1.18 upper 1.27 lower Is that a final drive ratio of 1.5:1???? Come on math whizzes!! Clue me in!!:drink: |
1.4986, I gues that's close enough to 1.5
Rene |
Your Formula 312 has 1.65 drives unless it was changed from what the factory put in it.
1 Attachment(s)
Thanks, Rene.... that is close enough!!
My Formula, per the spec sheet from the factory says 1.5:1 drives...... but this issue is with my Sonic 30SS...... This boat still remains a mystery in some ways!! But I love it. Performance is good enough but the ride is really special. Here it is. |
| All times are GMT -5. The time now is 06:04 AM. |
