-   -   Livorsi Shifter Controls: How do I reverse them? (https://www.offshoreonly.com/forums/drives-lower-units/168122-livorsi-shifter-controls-how-do-i-reverse-them.html)
JohnnyG 09-06-2007 10:31 PM
I have XR's and I want to switch from inward to outward prop rotation. Is it easy to adjust my Livorsi shifter controls so that forward (direction) is still forward on the shifter?
I've read that the XR's can run either dirction with no problem, but I may leave them reversed and I'll want to know how to fix the controls if that is the case.
John
Wild Card 09 09-08-2007 10:33 AM
Easy enough - just unscrew the shifter from the dash and lift it out. The levers have symmetrical arms on them. Just remove the shifter cable from one side and refit it on the other. Should take 10 mins.
Bravos run fine, either way.
