Bravo Low Water Pickup muffs
First boat with the Bravo drives and will be winterizing soon. I'm looking for the muffs to fit the low water pickup, which is all I have. If anyone knows where I can find these muffs, please let me know.
Also, first boat with twins and switchable exhaust. When I go to winterize, is there anything speacial I need to with the exhaust? Does the pink stuff need to be run through the system with the flaps both open and closed or does it even matter? Any other suggestions about the winterizing process I need to know? Thanks in advance. |
Name,
IMCO has a muff for there lower that uses low water pick up. I can only assume it will work with the Merc lower. I have not seen one but is available in the catalog. I think I saw it at around $45.. You can call them and inquire also.. D*ck |
Merc makes a flushing attatchment for lwp Bravo drives and Blackhawk drive. Part# 849996t
Where is Gas City, IN?
I bought a Merc low water flush a couple yrs ago. I think it was around $60. Have since installed a flush system and don't use the flush muff. Doesn't matter on the exhaust position. They both self drain. |
just south of Marion, halfway between Indy and Ft. Wayne along I-69
| All times are GMT -5. The time now is 11:10 PM. |
