-   -   hp limit (https://www.offshoreonly.com/forums/drives-lower-units/170619-hp-limit.html)
smoken02 10-07-2007 11:47 PM
hp limit
Can anyone tell me the hp limit of kaama surface drives with the borg warner transmissions? I have an 85 sutphen and would like to know how far I can mod the engines.
1CE 10-12-2007 12:37 AM
kamma
I believe they are rated @ 700 hp orig.from the factory, but I have seen guys run more than 1000 hp thru them. I have been running a pair for over 20+ yrs @ apprx 640 hp and have had good luck. (knock on wood) I run a synthetic gear lube. ? borg trans ? most Kamma set ups had Twin Disc transmissions. Where do u run it anyways ? jay 33-Sutphen "I'CE SCREAM" good luck.:boat:
smoken02 10-12-2007 12:53 AM
Run in Illinois,
1CE 10-17-2007 09:41 PM
Illinois
Originally Posted by smoken02 (Post 2303562)
Run in Illinois,
On the Great Lakes? Kamma drives I luv em. I hear the Lakes can get real nasty "big water" sea ya jay hope the info. helped !:sport009:
