-   -   Need gear set (https://www.offshoreonly.com/forums/drives-lower-units/170945-need-gear-set.html)
fountainfevr 10-11-2007 09:47 PM
Need gear set
Need upper gear set for 2000 bravo one th serial starts with OL
Smitty 10-12-2007 06:41 AM
What gear ratio??
1.50 or 1.36
I've got a set of 1.36 if needed.
thunderusone 10-12-2007 07:04 AM
I have a nice XR upper set with about 40 hours on them.
Mr Gadgets 10-12-2007 09:12 AM
If you are looking for new, then an upgrade kit is all that is available.
If used, I may have a gear or two?? Would have to check. I also have a couple of well used 1.36 sets.
I would recommend the upgrade kit route..
Hope this helps
D*ck
Noise Pollution 10-14-2007 09:00 PM
Hope this helps
D*ck
What is the upgrade kit? Does it make a bravo 1 into an XR?
Cost?
Mr Gadgets 10-14-2007 10:38 PM
NP...
The upgrade gear kit gives you new gears to replace the bravo1 gears with the weak floors. The new gears solve that problem that used to plague us years ago.. A standard bravo case can be upgraded to XR but the cost gets close to an XR upper. And your case needs to be in good shape to do it.. If you want costs.. it is better to discuss it on the phone.. Lots of options.. you want to compare apples to apples..
616-403-1006.. cell.
D*ck
Noise Pollution 10-15-2007 06:26 AM
Originally Posted by Mr Gadgets (Post 2305770)
NP...
D*ck
Thanks I'll give you a call later in the week.
fountainfevr 10-15-2007 06:26 PM
Thanks to evryone who replied. I ordered new gear set with evrythng tht I need it was $1500. Hope I made th right decsion. Guess we will find out when we put it bac togethr.
