-   -   Bravo Rear Cover Removal (https://www.offshoreonly.com/forums/drives-lower-units/173283-bravo-rear-cover-removal.html)
fastlane40 11-15-2007 03:23 AM
When removing the rear cover that houses the shift mechanism must the drive oil be drained before cover removal?
sandcraft 11-15-2007 04:14 AM
Only if you want to avoid an oil spill.
offthefront 11-15-2007 07:29 AM
pull the lower plug and drain a cpl of quarts ... if it hasn't been changed in a while be a good time to change the oil ...also when replacing the oil you need to pump in from the bottom ......m
