You In need of a alpha SS drive???
I have one with fresh rebuild and paint, black top silver bottom.. no shipping, in Flint, michigan
$4500 firm email for pic. [email protected] |
What is the difference between standard alpha and the ss?
SS is 3" shorter then a stock alpha. SS uses a shorter upper case and uses a outboard CLE lower gearcase.
5 mph on a 22 pachanga
2.5 inches shorter
RT |
Originally Posted by mountainmadness
(Post 2353575)
The upper case is not shorter. It's a standard dimension Gen 1 Alpha. I've never heard it confirmed they had HD upper gears from Merc but the parts breakdown I have for the drive lists the HD gear part numbers. The lower case is 2.5" shorter than a standard Gen 1 and has a crecent shape w built in nosecone. The cone is not as good as an Hydromotive design but gets the job done. The vertical driveshaft is also shorter and the water pump setup is a little different. It also has a low water pickup due to its shorter length. It's the same as adding an Imco shorty lower to a Bravo. |
trades?
pm me |
It DOES have a shorter upper, with no cast in cavatation plate like a standard alpha. It does have HD gears. I have one, and have had a few before the one I have now.
RT |
Originally Posted by RBT
(Post 2354836)
RT |
| All times are GMT -5. The time now is 09:36 AM. |
