-   -   Does a B max have a side fill plug? (https://www.offshoreonly.com/forums/drives-lower-units/178128-does-b-max-have-side-fill-plug.html)
Canada Jeff 01-23-2008 09:59 AM
I ask beacuse I have a drive gage on my current XR and if/when I go the a B max, I'd like to reinstall this gage.
Knot 4 Me 01-23-2008 10:28 AM
Looks like they have a provision for a temp probe.
http://www.bravoshop.com/bmax.html
Canada Jeff 01-23-2008 10:47 AM
Jesh, I just looked though the web site, didn't read that. Thanx. Guess I'll call them.
RBeyer 01-23-2008 10:03 PM
Mine fills at the top
B BOATER 01-27-2008 02:42 AM
Ht fills from the bottom by the prop hub with an air release on top. Fill the jug to about 1inch from the bottom they expand alot
RBeyer 01-29-2008 08:31 PM
Correct
Strip Poker 388 02-06-2008 05:55 PM
3 Attachment(s)
none of the Bmaxs Ive had were drilled for the side vent/plug. I guess you could drill it on a used one or if ya order new get Dean to drill it for the temp probs, Ive ran mine pretty hard and stopped and felt the top cap ,it was just warm. Ive never seen it burn the oil also. When ever I wash the transometc. I shoot the water hose in the top cap were the water exits to make sure its not stopped up.
Also the sides of the upper case are water jacked, make sure were to drill:eek:
Canada Jeff 02-07-2008 06:39 AM
O.K. thats good to know Strip, thanx. I wouldn't drive into it myslef, but if I go new, I will ask for a drilled port. I like having the gage. Besides, if/when I go to a B Max, I will have internal oil temp differences that should tell the story of how hard the drive is working.
