How to remove bulkhead fitting?
The one on the transom plate for the drive reservoir
oil. How do you remove it? (I broke it on the outside while doing a bellows overhaul, and my service manuals are 40 miles away right now). Pesky Varmint |
Originally Posted by Pesky Varmint
(Post 2454562)
oil. How do you remove it? (I broke it on the outside while doing a bellows overhaul, and my service manuals are 40 miles away right now). Pesky Varmint Nordic95 |
Thanks for the reply Nordic 95. I got it just after I had futzed
around and figured it out. On the inside of the transom (after removing exhaust manifold, water intake hose, oil cooler water hose) you push on a little clip in a quick disconnect fitting (while severely contorted over engine and everything else) and the fitting comes loose. Then you pry loose the little e-clip (you know, those things that go flying off to who knows where just when they come lose). Then you go outside and pull it out. Getting the e-clip back on is the thing I'm dreading the most putting it back together. I think I'll tie some very fine thread to the ring in case it wants to fly away. All this on a Nordic 35 with twin 575SCi's that I'm replacing bellows and hinge pins. Pesky Varmint |
| All times are GMT -5. The time now is 02:02 PM. |
