-   -   Extension box on 29 Fountain (https://www.offshoreonly.com/forums/drives-lower-units/180954-extension-box-29-fountain.html)
chewspit666 02-27-2008 09:41 PM
Has any one installed a extesion box on a 29 w/single 525 and is it worth it ? Thanks
Griff 02-27-2008 11:29 PM
I would check with Fountain and see if its a factory option on the boat. If it is or is not, you can bet they did some testing. You could also try the Fountain Forum.
Gladhe8er 02-28-2008 02:28 PM
I looked at a 29 with a 525 and ITS extension box. It came from the factory like that so it must work.
chewspit666 02-28-2008 10:54 PM
I called Fountain but they had no info, said that they did not test the smaller boats as much as the 35+ boats.
chewspit666 02-28-2008 10:56 PM
Hey Gladhe8er what year was the boat u looked at?
Gladhe8er 03-11-2008 09:13 AM
2004. It was at Ocean Performance in MD. Boat has since sold.
tblrklakemo 03-11-2008 11:04 AM
Im sure the its box will work fine, but its the longer and higher IMCO and stellings boxes that might put your drive up too high. You really dont need one since you have a notch transom.
KS_Jayhawk 04-12-2008 10:39 AM
Dude, what is a ITS box?
Wild Card 09 04-15-2008 01:54 PM
Check the Mercury Racing website - ITS is a 7" extended transom assembly with integrated hydraulic steering rams (like a #6 drive). Looks very clean. If you retrofit to an existing boat, it should be combined with a shorty lower to get good results.
