-   -   remote oiling for bravo 1 (https://www.offshoreonly.com/forums/drives-lower-units/181028-remote-oiling-bravo-1-a.html)
team Tickfaw 02-28-2008 07:58 PM
Been getting my outdrives ready and was wondering, how can you make sure the remote oiling bottle is actually working. I see elect. wires going to the bottle and assume its some type of selenoid. Looked in the book at wire schem. and it shows that a wire is supposed to go to a temp sending unit on block??? Am I reading that right? Thanks for any help, was just wondering......................................... ...
martins custom marin 02-28-2008 08:41 PM
the wires are for the low oil warning system that ties into water temp and low oil pressure, it needs to be tied into the blue with brown strip wire in your engine wiring harness, the other wire need to be grounded. you do not need to hook it up it just sounds the buzzer under the dash.
US1 Fountain 02-28-2008 08:52 PM
I have to remove, empty and clean my drive bottles every yr to get the sludge off the bottle bottom. Don't know what causes it as the drive lube is changed every yr and there is no water in the drives. The sludge could get thick enough to hold the float up from sounding the alarm if it where to get low on oil.
team Tickfaw 02-28-2008 09:15 PM
I noticed this also. Was sludge and funk in bottom of the bottles. But how does it work?
handfulz28 02-28-2008 09:40 PM
The resevoir is just that...holds fluid until it's needed. If you notice the level going down, something is wrong (assuming you've given it some time after a fluid change). Drive fluid doesn't actually circulate. If your warning buzzer(s) go off but water temp and oil pressure look good, check the level in the drive resevoirs.
whatabout1 02-28-2008 10:14 PM
The bottle is just a resevoir
As the oil in the drive heats and expands, it will push
some back into the bottle.
That is what breaks down into slug or it is just the lube breaking
down in the bottle.
martins custom marin 02-29-2008 06:51 AM
I have noticed that mercruiser quicksilver brive lube has a additive in it that has a tendency to sludge up in the resevore, its a friction modifier or stablizer. I have gone to lucas gear oils in my drive and have no sludge issues. amsoil extreme gear and alisen are products I have heard good things about.
Griff 02-29-2008 12:20 PM
Gravity:D
Mr Gadgets 02-29-2008 01:09 PM
Team Tick
There is a float switch in the bottle that will close contacts when the fluid level gets to that point. This will supply a ground or 12v (not sure which) to the alarm horn. There are several other switches that are wired in parallel that will sound the horn when problems arise.
That is the basis for the bottle alarm..
Hope this helps.
Dick
Vinny P 02-29-2008 06:37 PM
Originally Posted by Mr Gadgets (Post 2466087)
Team Tick
Dick
Hey Dick,
For the record, a ground is supplied to activate the siren. BTW, stop messing around on the internet and start building those drives and engine. :grinser010::p
team Tickfaw 02-29-2008 07:33 PM
That sums it up pretty good. Thanks for all the info I beleave I got it.
Mr Gadgets 03-01-2008 11:37 AM
Ok.. thanks Vinny.. lost track of my focus!! :) :)
tblrklakemo 03-04-2008 03:09 PM
I remove my bottle when changing out the lube and clean the sludge out....then I blow a little air into the unconnected tube until I hear it come out the drive oil drain hole. This way i know the tube and bottle are clean and flowable. You will have to top off your drive lube bottle a couple times after running it.
team Tickfaw 03-04-2008 04:09 PM
Thanks this all really helps.
sleek1 01-27-2009 04:50 PM
When you unscrew the wiring harness (bottom cap) do you use a torque wrench to put it back on or just a wrench and rule of thumb?
US1 Fountain 01-28-2009 01:01 AM
I just unplug the 2 wires at the bottle and remove the bottle and hose as a whole. The push clip at the transom for the hose can be a trick to undo at times.
Just snug on the bottom cap if you do take it apart. But I almost never take it apart to clean because it's a pain to work inside the bottle getting the flaot clip on/off. I just put a little gas in it and shake it till it's clean and then drain the gas thru the hose to clean it out also. Usually takes a couple gas changes to get it clean.
Then let it dry real good before reinstalling.
sleek1 01-28-2009 11:11 AM
Thanks for the pointer. I must have overlooked the disconnect at the bottom of the bottle.
