-   -   Question on #3SSM Repair (https://www.offshoreonly.com/forums/drives-lower-units/181840-question-3ssm-repair.html)
hurleyr 03-10-2008 05:32 PM
I'm restoring a pair of SSM3s and was woundering what the trick is to repair pits in the bare aluminum lower. Do they have to be welded and sanded out? Or, is there a good filler which can be polished to match the existing aluminum? Any help is appreciated.
Rob..
nocigarette 03-10-2008 05:54 PM
2 Attachment(s)
Just sand your as$ off.......It sucks but its the only way besides painting them.....Poor castings..
nocigarette 03-10-2008 05:55 PM
They look a lot better if you polish the top cap and flat part of the top.........
hurleyr 03-10-2008 07:17 PM
Looks like you are going through the same project. Some of my pits look too deep to sand out. I was hoping for an aluminum filler of some sort.
HotPursuit 03-28-2008 11:28 PM
spot weld and sand out. Also preheat the spot before welding.
open87 03-29-2008 10:58 AM
if pitting is too bad , i suggest cleaning with acid , then sand blast , clean with acid-again ,sand blast a second time and use this
http://www.evercoat.com/productDetail.aspx?pID=37
to fill the pits then prime with a good 2 part epoxy primer..
hurleyr 04-01-2008 07:55 PM
I agree, best way to do it. I just don't want to reseal the drives when the seals burn up. Drives were rebuilt about 10 hous ago.
I'm going to try the spot putty. If they don't clean up I'll tear them down and weld out the pits.
Thanks for the help!
hurleyr 04-01-2008 07:56 PM
I picked up Aluminox. Looks to be similar to what you are recommending. I'll let you know how it turns out.
HotPursuit 04-01-2008 09:01 PM
3 Attachment(s)
Just finished repair drysumping,new skegs & paint. I feel your pain. :drink:
HotPursuit 04-01-2008 09:06 PM
1 Attachment(s)
Old style skegs
hurleyr 04-08-2008 08:24 PM
Originally Posted by HotPursuit (Post 2509455)
Old style skegs
Wow! Turned out really nice. Did you replace the lowers or weld and cut? Either way it looks good.
HotPursuit 04-10-2008 09:56 PM
Cut and welded, the skeg is much thicker than I thought!
10x 04-13-2008 05:53 PM
Is there any speed gain with switching from the older style skegs to the new swept back styles?? Just wondering. Thanks.
HotPursuit 04-14-2008 09:59 PM
Should find out this weekend,but from what I have been told 5-6 mph gain on a cat compared to wet sumps.Not sure how much comes from the skegs. The handling of the newer skegs is alot better at 130+.
Plus no more 10 gal oil changes.
