trs gear ratio
Are there different gear ratios for trs drives.
If so how to determine correct ratio? I have two sets of drives and going to make one good set and want to use correct set up. Boat 34 scarab-III, 370 hp 454's. Also, looking for good reputable out drive shop in north Ga. Thanks, |
sup buddie..usually TRS are 1:50-1 if not all
Trs
Give me a call. I've been in the business for 27yrs. and build alot of TRS drives. Most are 1.50 there were some 1.33 gears around then.
Tony @ Merlin Marine 770 932-6694 |
Were the 1.33 Speedmaster II? TRS upper and II lower
Trs
That gear set came with a SBC power. I used them in several BBC setup's. 1.50 is the only gear set still avalible.
factory sent me odd gear combination many years ago - part of a "diesel drive" package if I recall correctly; could have been 1.33's, of course the TRII's had 2:1 ratio I think. Best of luck to you - Jeff
| All times are GMT -5. The time now is 09:17 PM. |
