-   -   To convert the upper case #6 wet to dry sump (https://www.offshoreonly.com/forums/drives-lower-units/182604-convert-upper-case-6-wet-dry-sump.html)
14 apache 03-20-2008 08:11 PM
Doing my own conversion to dry sump. Need somebody that can tell me what size to make the bearing squirters. All machine work is done on upper case. Some body told me .050 should be about right size to supply the bearings. If anybody can tell me what a stock #6 dry sump is. I have the factory squirters for the gears. Thanks Eric.
14 apache 03-25-2008 08:43 PM
Can anybody help me here. Thanks Eric
14 apache 03-29-2008 08:15 PM
Top Secret
There must of bin somebody that red this post that does not want to give up the information. But if i sent it to one of these guys that red this it would be know problem. Plus you need all of the special tools so just send us the drives we will fix you right up. And have a nice day. :hitfan:
Chris Sunkin 03-30-2008 08:48 AM
Probably like the formula for Coke.
If I'd have spent the time and $$ to develop a product that I was going to make a living on, I'd probably want to not give it away for free. They most likely had to ruin some parts to figure out the point between "too much oil/ losing power" and "not enough oil/smoking parts" lies.
HUSTLEthis 03-30-2008 06:37 PM
Originally Posted by shifter (Post 2501364)
What does the pump put out? When you find that out you need to figure out how many holes and how far from source. They should be different sizes.
bigger is not better. Check it with air/oil mix at psi of pump. watch nozzles and make sure they are working.
pat W
You've already got the info from the expert....
racesdad 03-31-2008 07:00 AM
send it to pat. he knows better than anyone
cougarman 03-31-2008 06:17 PM
(Pat / Shifter) sold the drysump side of the business to Vern Gilbert. 1-310-995-1670 or 310-328-9846
How ever Chris Sunkin hit the nail on the head pretty much.
Jon
