-   -   Trim pump problem? (https://www.offshoreonly.com/forums/drives-lower-units/183566-trim-pump-problem.html)
squaz 04-02-2008 12:46 PM
Trim pump problem?
I have a Bravo on a HP500 EFI that when I'm running the trim slowly bleeds down,or when it sits on the trailer ,within 24 hrs. it will be trimmed all the way down.Other than that it seems to work fine. I checked all the fittings for leaks.I never need to add oil so I know it's not leaking.Anyone have any ideas besides just buying a new trim pump.
Thanks,Guy
HotPursuit 04-02-2008 05:39 PM
You have leaking internal o-rings,or it could be the trim pump check valves not holding.
Tinkerer 04-02-2008 06:05 PM
It is the check valves inside the trim pump.
Been there had that problem.
RMPRam 04-02-2008 06:34 PM
How do you fix a "check valve leaking" problem?
sunchaser796 04-06-2008 10:42 AM
If its ever had water in the pump you are screwed. You have two choices; either replace the pump valve assembly or just buy a complete pump assembly. OR just call Doller Offshore Marine @ 954.237.0332
RMPRam 04-06-2008 07:33 PM
Can't the valves be "repaired"?
