-   -   Crank Flywheel Transmission TRS? HELP! (https://www.offshoreonly.com/forums/drives-lower-units/184489-crank-flywheel-transmission-trs-help.html)
Rookie 04-14-2008 02:35 PM
Some where there was a thread that someone attached the blown up parts view of this assy. If I recall it looked like there was a some sort of shim, but also acted like a bearing. It appeared to ~ 0.040" thick but acted like a bearing. Please correct me if i'm wrong, but if I'm right where the heck did it come from.
CIG3 04-14-2008 03:30 PM
There is no shim that I know of. Just the damper plate that mounts to the flywheel.
Rookie 04-14-2008 03:54 PM
I did not think their was anything between the crank and flywheel either, but when I got my parts back from the machine shop it was in their. I chalked it up to something fell into my box from someone elses stuff. But I remember seeing an exploded parts view and I swear that was in it. I saved that to my favorites on my computer, but after a minor Internet Explorer crash "MY Favorites" are gone.
Maybe it was to shim the flywheel closer to the starter, or spline engagement.
scarrab30 04-14-2008 05:24 PM
Rookie, call me I'll try to help you. Brian 815-469-6832
Rookie 04-14-2008 08:25 PM
I think I found it. But I have Borg Warner
http://www.kcmarinetr.com/images/tbear.jpg
http://www.kcmarinetr.com/merctrans.html
It was an old thread.
http://www.offshoreonly.com/forums/s...&highlight=trs
Audiofn 04-14-2008 09:45 PM
There is a small "bearing" more like a bushing that goes in the flywheel. It keeps the shaft from wobbling.
Rookie 04-14-2008 10:30 PM
I just pulled the other engine today and I have the output bearing. And it was a thrust bearing that was in my box. Do those thrust bearings go in cars also?? it still could have been in their by mistake. I tore the flywheel off and did not find on of those thrust bearings. Would it be on my tranny? haven't looked their.
http://i43.photobucket.com/albums/e3...e/DSCF0009.jpg
