-   -   oh CUT IT OUT !! (https://www.offshoreonly.com/forums/drives-lower-units/185273-oh-cut-out.html)
rumblfish1966 04-24-2008 12:17 PM
oh CUT IT OUT !!
Is the transom cutout the same for Bravo and TRS ? I see alot of older TRS twin hulls for sale cheap and I have Bravo/ 502s that are coming out of my 26 ft. (slightly shorter now nova) and looking for a home just wondering if I can put bravos on an origanal TRS boat w/out too much hassle for that matter if anyone has a project twin engine hull and needs EVERYTHING but the hull get ahold of me motors are a little long in tooth and need freshened up but it has alot of other new stuff
Wally 04-24-2008 01:19 PM
nope...gonna have to glass it shut and start over...there was once a trs/bravo conversion plate someone was making...dont know what ever became of that though...
rumblfish1966 04-24-2008 04:23 PM
that sucks
Ok well that sucks !! so much for easy how does Bravo one and TRS compare as far as strength, durability, cost to repair , which ones better for speed per HP plugged into it are the props the same ? I am actually eyeballing the older 31 ft. stinger in the classified section w/no power
Chris Sunkin 04-24-2008 06:09 PM
Not only is the hole different, the X is different too. Plus, the distance to the transom, which not only affects exhaust tailpipe length, it can really f-up a boat's balance. Ask any owner of an early Bravo-drive Topgun.
Major job.
BERUBE 10-06-2008 09:03 PM
Bruce, if often thought about my old sleeper Nova. Sounds like it has had an unfortunate demise. Just wondering what happend and if maybe you had any pics?
jeff1000man 10-06-2008 09:07 PM
Does stellings still make the adapter box, with the driveline that leaves the engines in the same place?
