Driveshaft o-rings
Is there anything special about the 2, black o-rings on a Bravo driveshaft just in front of the first u-joint or can you just take one to any auto parts store and match up the size to find a replacement? Had one fall apart when servicing a drive last night and didn't know if this is a Merc specific part or if any rubber o-ring would work. Thanks.
Anything should work, it just makes sure the bearing turns with the shaft.
Originally Posted by Mbam
(Post 2553270)
put a light film of grease on it so it goes in easy and does'nt stick in the bearing.
Originally Posted by hoozeyurdaddy
(Post 2555148)
| All times are GMT -5. The time now is 06:28 AM. |
