Shift not out of forword gear
Hi,
At 50% of shifting out of forword gear (Bravo I drive maybe same age like the boat 1988) it´s not posible to shift, i have to pull very hard and try 3-4 times till i have it out. There is no noise at any time I have a 1 1/2 year old lower cable and just changed the long cable because of this problem. Foreword in gear and reverse in and out of gear is absolutly no problem. The other 50% out off forword gear is also no problem. I think it could not be an adjustment problem when it´s only by shifting out of gear. Does anybody had this problem before ? I´m thankfull for any help Hans |
It may be the detent ball is worn or failed. It is part of the shift linkage under the rear cover. Its easy to inspect drain oil and remove cover.
Go and see ALEX in Eich am Rhein ( ALRA WASSERSPORT )
He can fix that in 15 min. for ya. Tell him Scotty refered you . |
Thanks MOBILMERCMAN and daredevil
Mobilemercman, is it repairable without pulling the drive when it´s that what you mean ? When the Ball could be bad could that part where the ball is working together be also bad ? Daradevil, I know Eich am See it´s about 30 Km down the Rhein an about 45 Km on street. Is it this Firm ? There is now first name at the website Ratajczak Wassersport Sandhof 8 67575 Eich If yes from where do you know him ? |
Yes thats him.
Cant let you know where i know him from ,but he maybe tell you. And yes ,you can repair that without pulling the drive. Its the rear cover ,the one with the 3 screws. Its the ball that locks the clutch,but not shure if that is youre problem. By the way i think alra is closed on Monday's ,not shure about that either. Zu lang her,als ich am see gewohnt hab.:D |
Thanks daredevil,
i will have a look into the drivehousing by my self. In the most cases i repair my boat by my self. I have a lot of tools and i´m a mechanik since 1986. But maybe when i dont have the time or it´s more difficoult than we think at the moment i will give him a call and make an apointment for the repair. Thanks an greatings from Germany Hans |
Hans, wenn du teile brauchst (egal was ) gib mir bescheid.
Da kann ich mir ein paar dollar verdienen und du hast das immer noch guenstiger wie EK der haendler .:D Gruss zurueck aus Florida.:cool-smiley-011: |
Schön !!!!
Habe mir schon immer einen Kontakt in USA gewünscht. Die Frachtkosten sind halt meistens sehr hoch zum Beispiel Propeller von B Blades 225,-USD + Zoll + 19% Mehrwertsteuer Waren gerade drüben, LA - Las Vegas - Lake Havasu City - Desert Storm Pokerrun ( zugeschaut und Augen rausgefallen) Das war ein bleibendes Erlebnis. Wie könnten wir in Kontakt kommen nehme an nicht übers Forum oder ? Gruß Hans |
The detent ball may be the problem I have seen the ball come out and randomly bind the shift linkage. The shift forks could be grooved from miss adjustment making shifting difficult. That would entail removing the top cap as well and a few special tools.
As far as adjustment goes the cables have an exact way to set them up with specific tools. If it is properly set up no adjustment is necassary. |
Thanks MOBILMERCMAN
Maybe i can open the housing on thursday this week, i hope it´s the smaller thing but it´s an older drive so the risk is high that i have to change all parts, i will see. I´ll stay in touch Thanks for answering Hans |
Hi,
The ball is ok. nothing looks worn. But there are the 2 disc where a + and - where the +I should be directly over ( or Under) the -I . On the upper i can see the + sign on the lower is nothing to see. It looks like an missadjustment that maybe could result in shiftingproblems. I don´t have the spezial tools and don´t have the time at the moment . I will bring it to an Repairshop. Thanks Hans |
Hello Hans,
go see Alex i bet he can help you cheap. Scott.:cool-smiley-011: |
| All times are GMT -5. The time now is 07:59 AM. |
