-   -   Trim Cylinder ground wire (https://www.offshoreonly.com/forums/drives-lower-units/193777-trim-cylinder-ground-wire.html)
lawdocx3 08-23-2008 02:15 PM
The ground wire on one of my trim Cylinders snapped in half. Do I need to replace this before I use the boat again?
txriverrat2001 08-23-2008 02:54 PM
No - It's a bonding wire to help fight off electrolysis. I would repair it - but if you don't leave the boat in the water for long periods of time - you'll be fine.
lawdocx3 08-23-2008 03:00 PM
Thanks, The boat sits on a lift. I wanted to go out tomorrow and then put it on the trailer to do some maintance. Good time to fix it!
Griff 08-23-2008 03:07 PM
Like was said, its to connect the drive to the mercathode system and prevent eloctolysis. Not a big deal and no reason not to take the boat out.
1CE 09-08-2008 12:30 AM
:grinser010:
