-   -   Bravo 3 on 502 formula (https://www.offshoreonly.com/forums/drives-lower-units/194832-bravo-3-502-formula.html)
nsformula 09-07-2008 07:22 PM
I just bought a used 95 Formula 271 and it has a b3 twin prop
drive which I thought was odd for this boat.
Boat is being shipped and I haven't used it yet so don't know how it is going to work.
Don't know what ratio it is, or if it's a b3 or b3x, but the stuff on mercury's w/site lists ratios quite different than Bravo 1's
that are normally on these boats.
http://www.mercurymarine.com/engines...hree_specs.php
These boats are known to be slow to get on plane, maybe the
twin prop would help.
Is this drive a good match for this boat???
waaldingo 11-16-2008 07:38 AM
Formula 271
We had a 271, year 97 with B3 ratio 1.81 and 26P props.
Formula choose this combination.
BUIZILLA 11-16-2008 07:42 AM
great combination actually, you'll understand once you use it..
mikebrls 11-16-2008 08:18 AM
I Have The Bravo 3 Twin Prop Drive's On My 38 Fountain Express Cruiser And They Work Great .
They Manuver The Boat When Docking Like A Dream . I Thought With This Size Boat I Would Need A Bow Thruster But With These Drive's I Turn The Front Or The Back Of The Boat With No Problem .
I Would Just Say No Hole Shot's From A Stand Still .
Good Luck
Mike
Barrydet 11-16-2008 04:36 PM
b3
My first formula fastech was a similar set-up. Great rig for water skiing and tubing. Our record was 7 adults spread across 5 obrien tubes, one driver and one observer. It took an hour to get everyone situated, ropes set and in position-but what a fun pull!! You will enjoy how well the boat manuevers around the docks.
